transmission output shafts |
JFG |
Jun 21 2017, 01:06 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I'm onto the gearbox now that the engine is back together.
I have new output shaft seals but i thought there were holes to put a bar through in order to lock it while i undo the bolt. I was wrong they are just indentations. Is there any way i can lock these off or will i need to take the box to a garahe for them to blast the bolts with an air gun? |
mark04usa |
Jun 21 2017, 01:32 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
IIRC the torque on the bolts is about 31 ft lbs, so should come off easily (I was lucky and mine were easily R&R'd). Be sure not to set the seals too deeply or they will fail and leak quickly as mine did...I had to do this job twice!
Lo-Fi Version | Time is now: 27th September 2024 - 10:37 AM |
