911 Front suspension is goofed help!, threads stripped on strut cartridge retainer |
tazz9924 |
Jul 16 2017, 05:03 PM
Senior Member Group: Members Posts: 716 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Ok so, i had a click from the front end of my car, i expected it to be the balljoints because their trash. come to find out the thing u screw in to retain the shock came off ( i did tighten the shift out of it before i installed it) and my newer koni shock has a hole rubbed in it and leaked all of its fluid. meanwhile the real killer is i cant rescrew the retainer back in because the threads on the tube thing are rubbed flat. My question is do i try to get the biggest tap ive ever seen or do i have to buy a whole new knuckle:( ?
The real killer is im moving to sacramento in two weeks and im driving the 914 down there! help! pm me if u got a drive side 911s koni strut/ knuckle thing ur willing to sell |
914Sixer |
Jul 16 2017, 06:28 PM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Early 911 Koni Reds with 3.5 spacing are rare items. Which ball joint does it take early or late?
tazz9924 |
Jul 16 2017, 06:37 PM
rgalla9146 |
Jul 16 2017, 07:08 PM
Advanced Member Group: Members Posts: 4,624 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Early 911 Koni Reds with 3.5 spacing are rare items. Which ball joint does it take early or late? One version is split at the bottom with a through bolt that grips the ball joint. The other version uses a wedge shaped threaded shaft with a nut to secure the ball joint. Koni S struts are precious. You're in for a hard search. |
Lo-Fi Version | Time is now: 27th September 2024 - 11:44 AM |
