Electrical Question #15 Need Help Please, I'm totally stumped this time |
76-914 |
Apr 6 2014, 06:33 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'm going to have several electrical questions. 1st, Is pin #8, on the 14 pin plug at the relay board, the only switched 12v+ source in the engine compartment? TIA, Kent
Spoke |
Jul 27 2017, 11:39 PM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Good find. That looks like a cheap QC connector. The melted one looks to be a bit bend top to bottom. You can replace the fuse carrier with a high quality fuse carrier like this one from Jegs:
Jegs Your resistance numbers look a bit high. Did you zero your meter by touching the 2 leads together and noting the resistance? Subtract the shorted-leads resistance from your measurement. Accurately measuring resistance in the sub 1 ohm region is difficult. Lots of times you'll have up to 1 ohm in the leads. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:12 PM |
