Gauge Pod, ..for Ashtray |
mmascari |
Aug 2 2017, 01:45 PM
Member Group: Members Posts: 322 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Does anyone know of a source for a gauge pod that fits in to the ashtray? Thanks.Mark
GeorgeRud |
Aug 3 2017, 08:44 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
VDO part number 240 803 is the rubber mounting two gauge bracket (though the picture is wrong). It's available directly through VDO on their website. Summit Racing carries the metal bracket.
mmascari |
Aug 3 2017, 05:35 PM
VDO part number 240 803 is the rubber mounting two gauge bracket (though the picture is wrong). It's available directly through VDO on their website. Summit Racing carries the metal bracket. I called Summit Racing and was told the rubber bracket that holds two is no longer available. VDO no longer makes it. |
dakotaewing |
Aug 3 2017, 06:08 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
VDO part number 240 803 is the rubber mounting two gauge bracket (though the picture is wrong). It's available directly through VDO on their website. Summit Racing carries the metal bracket. I called Summit Racing and was told the rubber bracket that holds two is no longer available. VDO no longer makes it. http://www.partdeal.com/vdo-2-gauge-rubber...AiABEgKbcvD_BwE No affiliation - |
maf914 |
Aug 5 2017, 06:07 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I called Summit Racing and was told the rubber bracket that holds two is no longer available. VDO no longer makes it. http://www.partdeal.com/vdo-2-gauge-rubber...AiABEgKbcvD_BwE No affiliation - Or maybe the VDO website: https://www.vdo-gauges.com/accessories/inst...t-mounting.html |
mmascari |
Aug 5 2017, 03:18 PM
I called Summit Racing and was told the rubber bracket that holds two is no longer available. VDO no longer makes it. http://www.partdeal.com/vdo-2-gauge-rubber...AiABEgKbcvD_BwE No affiliation - Or maybe the VDO website: https://www.vdo-gauges.com/accessories/inst...t-mounting.html I emailed VDO and their response: "That double rubber gauge mounting bracket has been discontinued. Best regards, Technical Support Team Business Unit CVAM" |
Lo-Fi Version | Time is now: 27th September 2024 - 05:45 AM |
