Single carburetor setup, Setup single carburetor/distributor for a 1.8 |
cmxiv 74 |
Aug 10 2017, 02:04 AM
Newbie Group: Members Posts: 11 Joined: 9-August 17 From: Los Angeles Member No.: 21,334 Region Association: Southern California |
Hi, I need to know if anyone around has a functional, decent (not performance, not perfect) setup that involves a center mounted carburetor on a 1.8 L engine. While I'm new to the subject I'm well aware about the inefficiency of the center mounted single carburetor setup on 914. Yes, it sucks ! But I have to deal with the facts and the reality. This are the facts: I bought my 74 1.8 already converted on single carburetor, (looks like a Weber, made in Spain, no other markings visible without removal) paired with a centrifugal advance distributor (not sure what model, no markings visible without removal) not know when was converted, or if the engine is stock or not. While has a decent acceleration response, decent power it runs very bad, inconsistent warm startup, high idle, rich, overall I can't find a "sweet spot". So far I changed the points, condenser, wires, spark plus, spark wires, distributor cap and rotor. The car is in what I call "active" repair/restoration which means that I have to keep it running and do work on it whenever I have the time and a place to work on it. So far is in my friends shop but while I will continue to have shop access I can not keep it there anymore, so it has to be parked on the street (it is registered and insured). For now I have to keep the car running with a single carburetor, so any other option is out.
Now... not sure if the centrifugal distributor is a good idea for this already bad setup, but I need opinion and advice from people who know how to do a proper setup for a single carb. I will add more info and photos over the next days Thank You ! PS. It looks like I have a 1.7 L not 1.8.The engine serial nr starts with EA, assigned to a 1973 1.7 L. Attached thumbnail(s) |
struckn |
Aug 10 2017, 12:39 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
Here's my '74 with same set up. If tuned correctly and float adjusted right it isn't a bad set up. Only thing you must be aware of is that the Cam should be for carb not Fuel Injection. FI was the way they came when new. Also I think this is the only set up that has Electric Choke to help with satrating, and these are quiter then dual carb, The fuel mileage is better too.
https://youtu.be/H4t0M2wrhu8 |
cmxiv 74 |
Aug 11 2017, 01:29 AM
Here's my '74 with same set up. If tuned correctly and float adjusted right it isn't a bad set up. Only thing you must be aware of is that the Cam should be for carb not Fuel Injection. FI was the way they came when new. Also I think this is the only set up that has Electric Choke to help with satrating, and these are quiter then dual carb, The fuel mileage is better too. https://youtu.be/H4t0M2wrhu8 No clue about the cam and no clue how to have it check without a huge mess. The electric choke is there and functional, probably set for warm climate (So Cal). I'm familiar with the electric choke system from Type 1/Pict on Beetle and KarmanGhia. Regarding being quiet...Can't tell ... the exhaust/muffler is really loud, it might be some performance package, not sure , but I have to dig around to find out. Are you running a centrifugal advance distributor or vacuum ? If vacuum , where is connected ? Thank's |
struckn |
Aug 11 2017, 02:41 PM
Reply, My 1.8 single carb car's distributor has a Pertronix Electronic module, or similar electronic module. It came installed on the car from the previous owner, no points, no vacuum advance, advance is done electronically. |
Lo-Fi Version | Time is now: 26th September 2024 - 11:15 PM |
