roof liner for targa top?, Yes or No? |
914 RZ-1 |
Sep 9 2017, 08:29 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I'm re-doing my targa top. Pulled off the old carpet roof liner. Is replacing this necessary? Does it do anything other than look good? Does it deaden sound, keep out heat, etc?
I was just going to paint the inside satin black. The top/outside will be sprayed with Wurth undercoating and then painted satin black. The top is somewhat flexible, not sure if this matters, but I thought I'd mention it. I figure the Wurth is flexible and I might consider putting a flex agent in the paint so it won't crack/spider. |
horizontally-opposed |
Sep 9 2017, 08:35 PM
Advanced Member Group: Members Posts: 3,443 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I'm re-doing my targa top. Pulled off the old carpet roof liner. Is replacing this necessary? Does it do anything other than look good? Does it deaden sound, keep out heat, etc? I was just going to paint the inside satin black. The top/outside will be sprayed with Wurth undercoating and then painted satin black. The top is somewhat flexible, not sure if this matters, but I thought I'd mention it. I figure the Wurth is flexible and I might consider putting a flex agent in the paint so it won't crack/spider. It probably doesn't do much to insulate sound, but I bet it helps keep the top from *reflecting* sound. Doesn't weigh much, and is a nice finishing touch, too. I'd reinstall. |
Lo-Fi Version | Time is now: 26th September 2024 - 11:13 PM |
