Advice needed -Difficult to get into 1st/reverse, As a result of adding the left side under warm air guide,- |
DRPHIL914 |
Sep 13 2017, 03:44 PM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
so figuring that i should put this missing piece on to help cooling of underside heads(this is what ive been told anyway),
i put the piece on and didnt think there would be a problem. car was in neutral when installing it and all went very smoothly all the holes lined up, Very hard to get it into 1st or reverse now- i will qualify this by adding that i have converted the exhause to a early Sshe's with triad- its a 2.0 75 car but all the exhaust etc is backdated so to speak- i may take this off when i get to Helen if it can't be rectified more easily- Thoughts? Anyone else ever run into this? Attached thumbnail(s) |
r_towle |
Sep 13 2017, 05:49 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
See if you can get someone to shift it while you watch from underneath.
It may be simple to put some spacers in to lower it enough so it stops rubbing. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:36 AM |
