hand throttle vs cold start circuit, Anyone use the CSC on Webers? |
bbrock |
Nov 13 2017, 03:50 PM
My Webers have the cold start circuits installed. While I'm replacing the floor pan and have easy access to the tunnel, I am thinking about adding a couple tubes to run cables from a hand throttle lever to the carbs to operate the chokes. Wondering if anyone has done this and whether it would provide superior cold starting to the traditional hand throttle. I live in the frigid north where it can freeze any day of the year, so I want the best cold start operation I can get. Thoughts?
theer |
Nov 13 2017, 07:07 PM
Senior Member Group: Members Posts: 681 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I had a hard time starting my 1.9l w/ dual 40 webers this weekend. Temps were in the low 40's (F). It finally started, but it took a few minutes.. maybe 7 -10 crank attempts?
Choke would have been very helpful. So - do I have this circuit already, or is it an add-on? Is there an electric choke available, like on the old VW's? |
bbrock |
Nov 13 2017, 08:09 PM
So - do I have this circuit already, or is it an add-on? Is there an electric choke available, like on the old VW's? Like Tbrown4x4 said, it depends. Some have them, and some don't. If yours have a mechanism like in the picture above that has a little lever a cable would attach to and a brass screened intake on the bottom, then you have it. If you have a solid plate screwed on there, then you could probably easily add it. Since most people who have them, take them off, I'd think they'd be easy enough to source. But I still have no idea how well they work. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:16 AM |
