hand throttle vs cold start circuit, Anyone use the CSC on Webers? |
bbrock |
Nov 13 2017, 03:50 PM
My Webers have the cold start circuits installed. While I'm replacing the floor pan and have easy access to the tunnel, I am thinking about adding a couple tubes to run cables from a hand throttle lever to the carbs to operate the chokes. Wondering if anyone has done this and whether it would provide superior cold starting to the traditional hand throttle. I live in the frigid north where it can freeze any day of the year, so I want the best cold start operation I can get. Thoughts?
Mark Henry |
Nov 17 2017, 01:43 PM
Cold start circuit I would disable, shit design. It will stick open, not if, but when.
Get your engine built by me and then tell me you're going to use the cold start circuit I'll write "warranty VOID" across your invoice. Even from my igloo I've never had a problem starting a weber car in the winter. That said any moisture will freeze in these carbs, in the real cold I've seen floats stick open and fuel spill out the tops, etc. Also single carb's I've seen them turn into a block of ice. My Gene Berg 42 DCNF's the plungers are tapped and screwed shut right from Berg, one winter I drove it every nice (but cold -20C) day, never had a problem with starting. BTW the /6 weber warm up lever isn't a choke, it just holds the throttle open so you have fast idle till warm. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:14 AM |
