My DIY raised spindles. How to |
jmitro |
Jan 6 2018, 08:33 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
Here is my process for raising spindles on standard 914 boge strut bodies. As documented elsewhere this modification allows you to lower the car but maintain correct camber curve and suspension travel. Raising by 19 mm allows use of 15”, 16”, or 17” wheels. I have converted to 5 lug using 911 front strut bodies, so my learning curve was to first modify these 914 struts. First photo is comparison of stock unmodified left side 914 strut body versus modified right side (my first one).
Attached thumbnail(s) |
jmitro |
Jan 6 2018, 08:54 AM
Close up of external sleeve on the lower edge. Again perfectly aligned and measured to original strut length, and orientation of the ball joint pin hole is maintained
Lo-Fi Version | Time is now: 27th September 2024 - 10:17 AM |
