New 914 Axels, Taking A Step Up |
Mblizzard |
Jan 9 2018, 01:40 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I know that new 914 axels are currently available from the Porsche dealer. I found them priced between $371 to $256 each plus shipping.
While I think the stock units will be more than enough for my current plans I just started think what would it cost to step up? I looked into the Tarett High Performance Axle Set. At $699 a set not cheap. If I follow things correctly they use an adaptor plate to install beefier CV joints. In the end you have essentially a very modern set up that can pretty much handle anything that is thrown its way for similar cost as the stock ones. Just have to find 500HP to justify the purchase. Anyone used these? |
Mark Henry |
Jan 9 2018, 01:57 PM
Are you doing a 5-bolt or 4?
I did the performance 5 bolt upgrade, the Sway a Way axles were half that price direct from sway a way. I also believe sway a way has stock size axles, they're a good company to deal with. http://www.914world.com/bbs2/index.php?showtopic=105728 |
Mblizzard |
Jan 9 2018, 02:01 PM
Mark Henry |
Jan 9 2018, 02:03 PM
Are you doing a 5-bolt or 4? I did the performance 5 bolt upgrade, the sway a way axles were half that price direct from sway a way. Right now just sticking with 4. Did not come across a list for a complete axel assembly form Sway Away. Fastest way to contact Sway a Way is to pick up the phone. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:24 AM |
