turn signals stopped working, just the indicators |
malcolm2 |
Jan 25 2018, 08:10 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
This happened to me before. I wish I could remember what I (or we) did to fix it. I did a search for my posts and it did not jump out at me. So if anyone remembers, or has recently repaired this, speak up....
OK here is the deal. I activate the turn signal lever and sometimes the dash indicator will blink twice. Most times not. I don't hear a CLICK when they do work. The Hazards do the same thing. The fuse is fine. The parking feature works fine on either side. Does everyone know that when the key is off and out, if you activate the signal lever, the lights come on on that side? Let know... |
BENBRO02 |
Jan 25 2018, 09:38 PM
Member Group: Members Posts: 483 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region |
My indicator only works when using the left directional and for one blink with the right directional and then goes dark. Bad relay too?
Spoke |
Jan 26 2018, 01:50 AM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
My indicator only works when using the left directional and for one blink with the right directional and then goes dark. Bad relay too? Same problem as the OP. Reason it works on left but not right could be different bulbs on left or right exterior. Left draws more current and keeps the secondary relay closing. Right doesn't draw as much current as left and the secondary relay doesn't remain pulled in on each flash. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:32 PM |
