Push rod tube seal leaks, sealant or not?? going to do mine second time and dont want leaks! |
DRPHIL914 |
Mar 7 2018, 10:05 AM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I was very careful last time with this, followed the directions of the late Captn,
just used oil as lube and slipped them in place. some leak some don't, many say no sealant some have used RTV - looking for more advice so I don't have to do this again Phil |
DRPHIL914 |
Mar 7 2018, 11:47 AM
i wanted to pulle the tin pieces under the cylinder heads anyway as i have newly cleaned and painted ones an there is quite a build up of dirt and oil there so its a good opportunity to clean things up . i am hoping i will be able to keep it clean for a while.
thanks for the suggestions- not sure if i will put any sealer on the large side or not- i might do one side with and one side without, see what happens- i assume that is red rtv Elliot? |
Lo-Fi Version | Time is now: 27th September 2024 - 08:26 AM |
