carbs sweating at gasket joint |
JFG |
Apr 24 2018, 01:03 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I was talking to someone at the weekend who advised it is likely to be the float height incorrect. Whilst i am in no under estimation of his knowledge i thought i would get some more input. No point opening them up twice.
Twin 40 weber idf. The motor ticks over very well when warmed up a bit and the short runs around the block (up to 2nd gear) runs nice. So no running issues so far. The problem is at the gasket joibt in the carb itself, both of them sweat fuel from this point. I've never had this before and my first thought was too much fuel pressure, i'm running a 3.5psi pump from cb performance but no regulator as yet. I set the floats as per instructions i found so from here i'm not sure what to do. These are my jet sizes etc Chokes 28mm, A.vents 4.5, Mains 115, Airs 200, Em.tubes F11, Idles 55, Pumps 50, N.valves 175......... |
JFG |
Apr 28 2018, 08:55 AM
I had the car out and running today to check the suggestions above. The only thing i didn't have time to do was recheck the float height.
The throats didn't look wet when idling so i'm thinking pressure is not to great. Still going to fit a pressure reg next week as a precaution. I tested the carbs with the synchrometer to and found that the barrel above number 4 would not adjust and would not idle above 3.5 whereas the other three are sitting at 4 happily. What should the reading be for weber 40's on a 1.7? I'm thinking the drop on 4 is down to valve adjustment. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:11 AM |
