> Shifter Linkage Upgrade
Montreal914
post May 27 2018, 03:35 PM
When I first saw the JWest shift linkage upgrade (NLA), I though it was a very elegant way to handle the support of the ball sleeve mechanism in the side shift gearbox console. I assume cost was the reason Porsche didn't do it that way.
I've always wanted to do something similar (IMG:style_emoticons/default/stirthepot.gif) . Being on a budget, I decided to modify/fabricated all of the components myself but pretty much all of this upgrade can be done with parts available through our member vendors here in one form or another.
Here we go! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/driving.gif)
Shift Console Preparation
All of this started when I got a spare gearbox with a broken shift console. I though this was the perfect candidate to play with since it can't be used in its current form. I cut the remaining part of the bushing tab and file the casting flush.
Then I prepared what would be the two new supporting tabs in which there would be oil impregnated bronze bushings. These tabs are made from a 1 1/4" x 3/8" aluminum flat bar. The 7/8" hole was machined in the right location (center 15mm from the console reference surface) to maintain the stock position of the shift rod.
The bronze bushings (McMaster Carr 6338K426) were grooved to accept a snap ring (McMaster Carr 98585A115) to secure them to the tabs.
Using a piece of 5/8" shaft, I do the first layout of the assembly.
Then, with a file (aluminum is a beautiful material), I did the weld preparation of the various surfaces as per recommendations from my welder.
Then my welder did his magic while taking his time and extra care to make sure the material didn't pull which would have resulted with bent tabs where bushings wouldn't have lined up and ruined the whole thing. Yes the preferred way of doing this would have been to weld first and machine after but that would have made the machining of the tabs more expensive due to an elaborate setup to hold the console. I would probably do it this way if I was doing it again, but since I had a good welder, he pulled it off nicely (IMG:style_emoticons/default/sunglasses.gif)
Then I used my trusted hack saw and files to smooth it out and bring it to a shape that could ressemble somewhat a stock casting form. (IMG:style_emoticons/default/w00t.gif)
Last, I reassembled the rest of the components with a fresh seal and the console assembly was ready to be installed on the gearbox. (IMG:style_emoticons/default/beer3.gif)
UROpartsman
post May 29 2018, 11:00 AM
QUOTE(Montreal914 @ May 27 2018, 02:35 PM) *
Nicely done! Another way would be to use bushings with a slightly undersized ID, and then ream to final ID through both bushings at once to ensure bore alignment.
King pin reamer
Or with an adjustable reamer: King pin bushes reamed to a perfect fit
Montreal914   Shifter Linkage Upgrade   May 27 2018, 03:35 PM
Montreal914   Next step was to start working on the front rod of...   May 27 2018, 03:54 PM
Montreal914   Firewall Bushing I lucked out on this one as I ha...   May 27 2018, 04:06 PM
Montreal914   Shift Console Installation Before installing the ...   May 27 2018, 04:21 PM
porschetub   When I first saw the JWest shift linkage upgrade ...   May 27 2018, 04:26 PM
Montreal914   Rear Shift Rod Again, before cutting anything, I ...   May 27 2018, 04:51 PM
Montreal914   Porschetub; I measured everything before modifyin...   May 27 2018, 05:03 PM
troth   I remember seeing something similar on Chris foley...   May 27 2018, 08:58 PM
mepstein   I remember seeing something similar on Chris fole...   May 27 2018, 09:42 PM
Mark Henry   [quote name='troth' post='2613293' date='May 27 2...   May 28 2018, 12:31 PM
stugray   I remember seeing something similar on Chris fole...   May 28 2018, 12:22 PM
Blue6   Nice work. Thank you for documenting and posting :...   May 27 2018, 09:07 PM
Montreal914   Yep, didn't invent anything here, just made my...   May 28 2018, 11:11 AM
jim_hoyland   Fantastic DIY project , Thanks for sharing the pic...   May 28 2018, 07:07 PM
GregAmy   You are clearly a man of fab talent and motivation...   May 29 2018, 06:41 AM
maf914   Excellent thread, Montreal914. Thanks for posting...   May 29 2018, 07:15 AM
Montreal914   Excellent thread, Montreal914. Thanks for postin...   May 29 2018, 01:35 PM
porschetub   Excellent thread, Montreal914. Thanks for posti...   May 29 2018, 11:50 PM
UROpartsman   Then my welder did his magic while taking his tim...   May 29 2018, 11:00 AM
Dr Evil   Very nice. Thanks for the pics and write up.   Jun 1 2018, 01:47 PM
Mueller   Very nice, I might have to borrow a few of your de...   Jun 1 2018, 02:00 PM
Montreal914   Please do! :beer2: This is a gathering of m...   Jun 1 2018, 08:09 PM
whitetwinturbo   :popcorn: :smash: :trophy: ....great stuff!   Jun 12 2018, 09:24 AM
16 User(s) are reading this topic (16 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 23rd November 2024 - 07:42 AM
