Bumper top with a broken stud, How do you repair this? drill it out?(i dont know how they secured the stud into the bumper |
DRPHIL914 |
Jul 20 2018, 12:49 PM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I guess the answer would lie in knowing how it is put in there . is the stud in a nut that is welded to the inner metal plate/inner frame? or is it a stud that is welded to the plate itself?- so how to put a new stud in??
and is theis a OEM bumper top? Attached thumbnail(s) |
dr914@autoatlanta.com |
Jul 20 2018, 01:38 PM
914 Guru Group: Members Posts: 8,055 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the easiest thing to do would to grind flat, drill a smaller hole and tap and install a smaller bolt with a washer
I guess the answer would lie in knowing how it is put in there . is the stud in a nut that is welded to the inner metal plate/inner frame? or is it a stud that is welded to the plate itself?- so how to put a new stud in?? and is theis a OEM bumper top? |
sb914 |
Jul 20 2018, 02:11 PM
Surf Guru Group: Members Posts: 4,365 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
the easiest thing to do would to grind flat, drill a smaller hole and tap and install a smaller bolt with a washer I guess the answer would lie in knowing how it is put in there . is the stud in a nut that is welded to the inner metal plate/inner frame? or is it a stud that is welded to the plate itself?- so how to put a new stud in?? and is theis a OEM bumper top? (IMG:style_emoticons/default/agree.gif) I've done that twice! |
Lo-Fi Version | Time is now: 27th September 2024 - 01:51 PM |
