Clutch issue or something more?, Need to erase the grind |
MiniStevieG |
Feb 10 2019, 05:17 PM
Member Group: Members Posts: 179 Joined: 25-January 19 From: Dallas, TX Member No.: 22,827 Region Association: Southwest Region |
Experiencing some issues when shifting gears. I’m finding that even with the clutch pedal pressed the entire way to the floor I’m grinding a bit when shifting. I did a bit of research and decided to adjust the tensioner on the back cable assembly.
First I tried tightening the nut thinking this would help the clutch to engage sooner but in fact the issue appeared worse after I tightened it. I then adjusted the nut back to where I started and tried loosening it but that didn’t help either. Anyone care to take a stab at what the issue might be? New cable assembly maybe? Pressure plate? Thanks everyone!! |
76-914 |
Feb 14 2019, 09:27 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The most important pitfall to avoid is getting slag inside the tube. If you choose to weld on the tube itself you can insert a same size drill bit inside the tube when welding to prevent this. You can clamp it with a "U" or "J" bolt to the side or bottom of the tunnel. You can also wrap a strap/clamp around the tube then weld the strap/clamp to the tunnel wall but not weld the strap to the tube if your concerned about slag. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 10:02 AM |
