How do I....?, I need to create a "switched" ciruit |
Carlitos Way |
Nov 26 2004, 02:16 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
For some unknown reason, the PO had run the fuel pump off the Tail Light circuit, so I need to correct this. I tried other fuses in the fuse box, but they all seem to be either on all the time, or only on when specific things are turned on. So I decided to do things "better."
I would like to run a "switched" circuit to my fuse box, so I can have the fuel pump active only when the engine is running (ignition in the ON position?). I have upgraded to the 15 fuse box and would like to create two new switched fuse circuits for my fuel pump and my stereo (one each), that way I can get ahead of the game, and know exactly where everything is, rather than splicing more stuff and screwing around with the electrical system. Can you help/offer any suggestions? |
ws91420 |
Nov 26 2004, 05:36 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Yes you can jumper it. But you will be using the original wiring. Are you using FI or carbs? What year car?
Lo-Fi Version | Time is now: 27th September 2024 - 11:08 AM |
