1st & Reverse are starting to grind |
CoronaMike |
Mar 29 2019, 05:53 PM
Member Group: Members Posts: 152 Joined: 11-February 19 From: Maryville, TN Member No.: 22,868 Region Association: South East States |
Hi everyone.
(1974 1.8) So, I've noticed over the past couple weeks that slowly 1st gear and reverse are becoming harder to get into without it grinding a little. I'm wondering if something is just out of alignment? Ideas? Thanks! Mike |
struckn |
Mar 29 2019, 08:00 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
Just to add, this happens a lot and the easy thing to try first is to Shift to 2nd before shifting down to 1st which usually helps stop the grinding. Also, before coming to a stop such as when coming to a full stop at a red light, down gear to 2nd and with the clutch peddle still depressed then shift down to first and keep the clutch peddle depressed until ready to continue driving. Not the best fix but easiest thing to do with out making a mechanical adjustment. I do this and found the problem with the grinding actually stopped after a while?
Lo-Fi Version | Time is now: 27th September 2024 - 12:43 PM |
