Main Targa Seal Install, A/K/A Defeated by rubber |
johnlush |
Mar 28 2019, 05:56 PM
What's all this then? Group: Members Posts: 371 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,108 Region Association: Rocky Mountains |
After way too many hours on this I'm out of ideas. Yes, I've searched and it looks like struggling with the installation of the main targa seal is part of the game but it is possible. That has not been my experience. I got the right a-pillar portion installed by sliding it down from the top although everything I've read said that wouldn't work and to seat the inside lip in the channel and work the outer lip into the trim with a suitable tool. So far so good and off to the left side. Nothing and I mean nothing works. Tried sliding from the top and it binds about a third of the way in and will go no further. I've already examined the track for dings and crud and it's clean and mostly straight. So I give up on that idea and decide OK, let's do the one lip at a time thing. I can't get it to start using anything I try. I have flat nylon tools, screwdrivers, putty knives, you name. it.
I've heard it alluded to that there are pictures and/or videos of how the #%^& to do this but I can't find them. Any words of wisdom would be greatly appreciated... |
johnlush |
Mar 30 2019, 05:10 PM
Thought I'd update this. It's in. I ended up using the "Mikey Method" on the left hand vertical piece. I was able to slide in the right side with a lot of pushing, pulling and coaxing but the left side would invariably bind about a third of the way in. Given the choice I prefer the slide it in method as it seems less likely do damage the new seal.
I'm assuming I need to trim the vertical legs to match the rubber wing window blocks? Utility knife? Things I learned: • This is not a quick job - at least not for me. I suppose it's like most things, the more you do the easier it gets. • You will swear and sweat and your fingers will hurt during and afterward. • You'll be afraid that all of the pulling, pushing, poking, etc. will destroy your new expensive seal. • Glycerin is not readily available at all drug stores - I went to Walgreens because that's what's here. • Water-based "personal lubricant" works well and does seem to be easier to find. • You may have a somewhat awkward conversation with the young pharmacy employee about the relative merits of glycerin versus sex lube. (IMG:style_emoticons/default/lol-2.gif) • You will probably need a beer break somewhere in the process and another one afterward while you put away the 973 various tools you got out because "that might be just the perfect tool!" Thanks again for all of the suggestions! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 08:58 AM |
