crankshaft bearing dowel pins, engine rebuild |
Natedog |
Nov 27 2004, 05:01 PM
Member Group: Members Posts: 107 Joined: 20-October 03 From: Fort Collins, CO Member No.: 1,265 |
Hello -
So I've started my first engine rebuild and I have a question: I have a 73 2.0 litre 914. On the crankshaft bearings, are there supposed to be small dowel pins holding the bearings in place? The Haynes manual shows a diagram with the dowels but they aren't mentioned in the reassembly directions. The dowels ( 4 total ) should be about 5 mm diameter by 8 mm long. Do I need them? What's the correct size? And where can I get some!? Thanks for your help! Cheers Nate Fort Collins CO 73 914 2.0 73 VW T3 Squareback |
Allan |
Nov 27 2004, 05:32 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
They keep the bearings from spinning. Not sure where to get them. You might try Jake Raby.
Lo-Fi Version | Time is now: 27th September 2024 - 08:36 AM |
