Resistor Spark Plugs, Any reason not to? |
bbrock |
May 7 2019, 12:03 PM
So it looks like NGK BR6ES are more readily available locally, and less expensive than standard B6ES. Plus, they will suppress electrical noise from the engine. Is there any reason not to use them?
bbrock |
May 8 2019, 09:45 AM
Finding Bosch plugs is a bit like chasing down the rabbit hole because of Bosch constantly changing names and part numbers. As near as I can tell, the Bosch Super Plug cross references to the WRCC+ plug which is a resistor type plug. Do you know if that's true? Do you happen to have a current part number for the plugs you use?
Lo-Fi Version | Time is now: 27th September 2024 - 01:45 PM |
