Measurements for 911 Flag Mirrors, outside measurements with mirrors on |
jim912928 |
Dec 3 2004, 11:36 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Well, I finally got around to taking some measurements. I did not take the mirrors off, but rather took measurements from 3 points on each door to the base of the rubber gasket. On this first picture...the key to the alignment is the yellow line...that line when looking at the car from the front should be vertical on both sides!
Also, for strength, you must use the 911 backing plate. I riveted mine on after having the holes cut in. Drivers side: Attached image(s) |
Carl La Fong |
May 23 2019, 11:21 AM
Member Group: Retired Members Posts: 137 Joined: 27-March 19 From: west Member No.: 23,000 Region Association: None |
Mounting flag mirrors on the 914 requires great care in making sure they are parallel to the ground. One or two degrees up or down is very noticeable and looks... not great. Be careful taking on this project. It took me a week before I started drilling holes in the doors. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 11:46 AM |
