On a 5 lug conversion, are the rear studs longer than the fronts? |
turnaround89 |
Jun 29 2009, 12:04 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Is the most common length for a wheel stud for fuchs rims 45mm? Are the rear lugs supposed to be longer at 52mm, or are they also 45mm?
Also, why are wheel studs 7 dollars a stud? Have to buy 20 studs, 140 for studs is a little crazy |
Spoke |
May 23 2019, 04:55 PM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Here's the rear hub of my '86 930. Not sure how long these studs are.
Had to pull the hub since the inside bearing blew out. I listened to the whining a little too long. (IMG:style_emoticons/default/poke.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 07:58 AM |
