Help car not cranking |
Joshlm |
Jul 30 2019, 01:51 PM
Newbie Group: Members Posts: 3 Joined: 16-March 19 From: Clovis CA Member No.: 22,964 Region Association: Central California |
So 2 days ago I was driving my 914, was doing fine all day and then I came home and about 20min later I went to start it and nothing. It’s not cranking at all. I charged and checked the battery, it’s fine (12.7v , Under load it’s 12.2v). I tried tapping the starter solenoid and nothing. I used screwdrivers to check and when I made a contact between 2 points on the solenoid I got a buzzing sounds does this mean my starter is fine? The car did not crank, but I heard the starter operating. When I made a connection between the actual starter and the solenoid I just got sparks.
With the key on accessory mode the radio and electronic work. Recently the generator light went out but I haven’t had a chance to look at it. I checked the voltage at the solenoid and it was fine (12.7). I can’t check my earths right now because my multimeter doesn’t have the continuity option (it’s the $7 harbor freight one). Does 72 have the under passenger seat relays? I didn’t see anything under the seat in my car. What do I need to test / check on my relays in the engine compartment? And does that yellow wire need to be connected to the solenoid? I didn’t see anywhere it would have mounted. Thanks in advance 72’ 1.8 |
Joshlm |
Jul 30 2019, 03:01 PM
I got it figured out, it was that yellow wire. Next I will do a good electrical cleaning. Thanks!
Superhawk996 |
Jul 31 2019, 12:13 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I got it figured out, it was that yellow wire. Worst thing about 914's: Archaic Spade Connectors. The lack of water proofing and positive locking is simply hilarious as compared to modern vehicles. Best thing about 914's: Archaic Spade Connectors. Available everywhere and easy to fix. |
ValcoOscar |
Aug 1 2019, 12:08 PM
Garage Life Group: Members Posts: 2,468 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
I got it figured out, it was that yellow wire. Worst thing about 914's: Archaic Spade Connectors. The lack of water proofing and positive locking is simply hilarious as compared to modern vehicles. Best thing about 914's: Archaic Spade Connectors. Available everywhere and easy to fix. You are so correct, I've learned. Now I stock these at home along with shrink tubing. Oscar |
Lo-Fi Version | Time is now: 27th September 2024 - 11:04 AM |
