Questions about Air Conditioning, ... help me make my car cooler! |
tygaboy |
Aug 1 2019, 05:06 PM
914 Guru Group: Members Posts: 5,431 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Hi World - I need some info:
I'm working to add A/C to my build and I found this little set up that's 10.5" wide, 8.5" deep and 4.5" tall. What I don't know is what's possible in terms of orientation of these evaporator/ fan units. I know they have to drain any condensation (and not into the motor, etc.) but assuming I address that: - Is there any appreciable impact to how the evap unit performs if it were stood on end, turned upside down, etc.? Essentially, does refrigerant care about flowing up vs down vs sideways? - Do any of the other components, like the expansion valve, care about orientation? If needed, I'm totally OK with cutting up the case, making one that suites my needs and reusing the components. Or, if there are other considerations, if I'm missing something, please let me know. Thanks in advance for any help! Chris Attached thumbnail(s) |
Chris914n6 |
Aug 1 2019, 05:48 PM
Jackstands are my life. Group: Members Posts: 3,393 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
You can mount it however you want, freon don't care.
The motors will depend on the bearings, but many factory blowers face vertical. You will need a good drain or it will get stinky. You can mount it IN the center console if you wanted, it looks small enough. (lol I type slow) |
tygaboy |
Aug 1 2019, 05:57 PM
You can mount it however you want, freon don't care. The motors will depend on the bearings, but many factory blowers face vertical. You will need a good drain or it will get stinky. You can mount it IN the center console if you wanted, it looks small enough. (lol I type slow) So it's sounding safe to "Go Vertical!", at least for the evap stuff. I can work out the fan situation. I may want to use something different anyway. Thanks! |
Lo-Fi Version | Time is now: 27th September 2024 - 12:29 PM |
