Parking Brake...well that explains it |
advman89 |
Aug 5 2019, 07:31 AM
Member Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest |
When I pulled the tires off this weekend to bleed the brakes...found that the parking brake was not connected to the caliper on either side.
I have searched for the parts to connect the cables, but can't seem to locate them. |
mbseto |
Aug 5 2019, 01:00 PM
Senior Member Group: Members Posts: 1,257 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Until you get the correct parts, you can just use a small bolt the size of the hole in the cable end........ Be careful to adjust cables so the bolts/pins just begin to touch the lever and not move it from their resting position more than 1/16".... GN Any reason this wouldn't work long term if it is not a show car? |
defianty |
Aug 5 2019, 02:33 PM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
Until you get the correct parts, you can just use a small bolt the size of the hole in the cable end........ Be careful to adjust cables so the bolts/pins just begin to touch the lever and not move it from their resting position more than 1/16".... GN Any reason this wouldn't work long term if it is not a show car? Having the pin enables the end of the handbrake cable to rotate slightly as the angle changes when the cable is pulled. If you tighten a bolt though it won't be able to rotate. However saying that on one of mine did have a bolt with a nyloc nut on that wasn't done up all the way. It worked but obviously not correct. |
Chi-town |
Aug 5 2019, 02:36 PM
Senior Member Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
I have a ton of them if you need them.
Remember to set the pad gap also otherwise you can have a low pedal |
Lo-Fi Version | Time is now: 27th September 2024 - 10:18 AM |
