OT but hopefully interesting: single to dual brake line conversion |
Tdskip |
Aug 11 2019, 06:10 AM
Advanced Member Group: Members Posts: 3,697 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
So I need to get this thing ready for a charity event and that includes new brake lines. I converted it to a two line, split front and rear, brake system for safety purposes but haven’t finish3s the hard lines yet.
I’m thinking having a proportioning valve in the system so I can adjust the front/rear bias would be a good idea but am not sure how to plumb that. I have a conventional mid ‘90s Toyota dual M/C now. Figured our racers here have dealt with that so thought I’d ask. For those that have done this where did you put the valve? I’ve seen two types - one where both lines from fhe MC go to a combination valve and splitter (pictured below, just an example I haven’t ordered this yet or decided to go this way) OR a set up where only the rear line goes through the valve. Thanks in advance for any ideas and coaching. |
Tbrown4x4 |
Aug 11 2019, 04:24 PM
Senior Member Group: Members Posts: 706 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I assumed 914, but it must be for a Land Cruiser.
To add to the confusion, your combo valve diagram is the type with a proportioning valve inside already. (Hence the term "combo") I'm not sure how well adding a second adjustable valve would work. You're only trying to prevent rear brake lock up under HARD braking. |
Lo-Fi Version | Time is now: 27th September 2024 - 03:24 PM |
