odometer stops at 99500 exactly, 1974 914 1.8 |
brcacti |
Sep 3 2019, 07:48 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, do you think it is broke or do I need to start dismantling the dash to take out the odometer to inspect it, reset it?
914forme |
Sep 3 2019, 07:59 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
95% broken. Speedo needle still works?
Speedogears.com is your friend. Has to be taken apart gear most likely broken into pieces. Need to measure over size, they will tell you how on their site. Find the nearest larger size and it will need to be filed, turned, sanded, shaved to the proper size. Put it back on, and well it is fixed. Lube it back up, test it, and your good to go. Or if you don't think you can DIY it, just send it out to one of the many rebuilders. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:18 AM |
