Shift Rod Pin, Removal |
ballsyfacts914 |
Sep 14 2019, 01:30 PM
Member Group: Members Posts: 82 Joined: 28-August 19 From: East Bay Region-SF Bay Area Member No.: 23,413 Region Association: Northern California |
The shift rod has a pin right after the firewall that connects the rod to the transmission. Both of the bushings were completely gone, as in not even there. Not really sure how I drove it home. Everything I can find shows how to remove the pin but the bushings are part of the process...I don't have bushings so everything on removal doesn't work.
I have tried using a vice, I have tried a punch but nothing friggin works... (IMG:style_emoticons/default/blink.gif) I have managed to damage ever so slightly one end of the pin but don't think it is a big deal, no mushrooming. How do I get this damn pin out? Thanks |
JOEPROPER |
Sep 14 2019, 01:34 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I did mine today. I pressed it out with a hydraulic press, but you can use a bench vise if you have a decent one. 914Rubber has all the bushings or you can buy as a kit with a new boot and everything. Mine went pretty smooth, so while I was in there, I cleaned and painted the rod.
Lo-Fi Version | Time is now: 27th September 2024 - 08:03 AM |
