Pressure plate wear., Causes. |
914Toy |
Mar 19 2020, 08:21 AM
Senior Member Group: Members Posts: 727 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
To the brain trust: re slight shudder when engaging the clutch in first gear to begin moving forward.
The clutch assembly is a Sachs brand 228 mm and was installed new about two years ago onto a new flywheel on my 2.7 911 engine, and now has some 5,000 street miles on it. Also new was the throw out bearing (Sachs) and nylon bush under the clutch fork. I expected to see some clutch disk "burn" deposit on the fly wheel and/or pressure plate. To my surprise, while there were some small deposits on the flywheel and pressure plate, these parts and the clutch disk appear to be in near new condition - little measurable or obvious wear. However, the tips of the pressure plate "fingers (see pic) were worn down where the throw out bearing (TOB) contacts them. This suggests the TOB is slipping on the finger tips causing friction and wear. The TOB feels solid and spins freely like new. I don't believe this is normal wear. Any thoughts/advice? |
TravisNeff |
Mar 19 2020, 08:32 AM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I can't help with the reason for wear. I would make a crazy guess and say that maybe you have your clutch adjusted too tight. You should be able to pull your clutch pedal back by hand about 1/2 inch or so to know if you were in the ballpark. But if that was the case you would see evidence everywhere else with the flywheel getting hot and disk wear.
Honestly it doesn't look too bad. Except for the oddity of the 11 o'clock position, that looks like it is cut deep and the rest look a little more polished (maybe it is just the picture). Since it it always spinning you would think the wear would be the same across all fingers. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:14 AM |
