Pressure plate wear., Causes. |
914Toy |
Mar 19 2020, 08:21 AM
Senior Member Group: Members Posts: 727 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
To the brain trust: re slight shudder when engaging the clutch in first gear to begin moving forward.
The clutch assembly is a Sachs brand 228 mm and was installed new about two years ago onto a new flywheel on my 2.7 911 engine, and now has some 5,000 street miles on it. Also new was the throw out bearing (Sachs) and nylon bush under the clutch fork. I expected to see some clutch disk "burn" deposit on the fly wheel and/or pressure plate. To my surprise, while there were some small deposits on the flywheel and pressure plate, these parts and the clutch disk appear to be in near new condition - little measurable or obvious wear. However, the tips of the pressure plate "fingers (see pic) were worn down where the throw out bearing (TOB) contacts them. This suggests the TOB is slipping on the finger tips causing friction and wear. The TOB feels solid and spins freely like new. I don't believe this is normal wear. Any thoughts/advice? |
SirAndy |
Mar 19 2020, 10:09 AM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
This is the part that the throwout bearing is riding on.
Do you like to sit at a stop while in gear with your foot on the clutch? Seems like there was a lot of contact between the bearing and the pressure plate. (IMG:style_emoticons/default/idea.gif) |
Root_Werks |
Mar 19 2020, 11:10 AM
Village Idiot Group: Members Posts: 8,424 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
This is the part that the throwout bearing is riding on. Do you like to sit at a stop while in gear with your foot on the clutch? Seems like there was a lot of contact between the bearing and the pressure plate. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/agree.gif) I see that every once in a while. Most cars only take a few mm's before the T/O bearing will rest against the pressure plate. Keep that foot off the pedal unless you're gonna use it. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:51 AM |
