Pressure plate wear., Causes. |
914Toy |
Mar 19 2020, 08:21 AM
Senior Member Group: Members Posts: 727 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
To the brain trust: re slight shudder when engaging the clutch in first gear to begin moving forward.
The clutch assembly is a Sachs brand 228 mm and was installed new about two years ago onto a new flywheel on my 2.7 911 engine, and now has some 5,000 street miles on it. Also new was the throw out bearing (Sachs) and nylon bush under the clutch fork. I expected to see some clutch disk "burn" deposit on the fly wheel and/or pressure plate. To my surprise, while there were some small deposits on the flywheel and pressure plate, these parts and the clutch disk appear to be in near new condition - little measurable or obvious wear. However, the tips of the pressure plate "fingers (see pic) were worn down where the throw out bearing (TOB) contacts them. This suggests the TOB is slipping on the finger tips causing friction and wear. The TOB feels solid and spins freely like new. I don't believe this is normal wear. Any thoughts/advice? |
GregAmy |
Mar 19 2020, 04:46 PM
Advanced Member Group: Members Posts: 2,385 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
That wear is between the pressure plate and the throwout bearing.
The throwout bearing is a bearing (duh) that has a surface that rotates with the pressure plate. There should be minimal relative movement between the two. It appears like the part of the throwout bearing that interfaces with the pressure plate is not properly rotating; instead of rotating with the pressure plate it's wearing on the pressure plate. Ergo...my call is "bad throwout bearing". Contributing factor...bad flywheel pilot bearing, allowing the tansaxle input shaft to bind and/or move non-coaxially. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:19 AM |
