Pressure plate wear., Causes. |
914Toy |
Mar 19 2020, 08:21 AM
Senior Member Group: Members Posts: 727 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
To the brain trust: re slight shudder when engaging the clutch in first gear to begin moving forward.
The clutch assembly is a Sachs brand 228 mm and was installed new about two years ago onto a new flywheel on my 2.7 911 engine, and now has some 5,000 street miles on it. Also new was the throw out bearing (Sachs) and nylon bush under the clutch fork. I expected to see some clutch disk "burn" deposit on the fly wheel and/or pressure plate. To my surprise, while there were some small deposits on the flywheel and pressure plate, these parts and the clutch disk appear to be in near new condition - little measurable or obvious wear. However, the tips of the pressure plate "fingers (see pic) were worn down where the throw out bearing (TOB) contacts them. This suggests the TOB is slipping on the finger tips causing friction and wear. The TOB feels solid and spins freely like new. I don't believe this is normal wear. Any thoughts/advice? |
rgalla9146 |
Mar 20 2020, 01:11 PM
Advanced Member Group: Members Posts: 4,624 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Shudder at take off ?
Possible bent throw-out fork or uneven wear where lugs of TOB fit into fork. TOB also needs to rotate freely on axis of lugs As mentioned incorrect clutch adjustment.....no free play |
Mark Henry |
Mar 20 2020, 05:59 PM
Shudder at take off ? Possible bent throw-out fork or uneven wear where lugs of TOB fit into fork. TOB also needs to rotate freely on axis of lugs As mentioned incorrect clutch adjustment.....no free play (IMG:style_emoticons/default/agree.gif) This is one you should check especially if you have a heavier than stock PP. I welded in some gussets on my shaft arms (forks) because I have a HD PP on my 3.0 /6 conversion. HD RB shafts and/or welding up the forks are common in the type one trans crowd. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:52 AM |
