2.0 Cylinder Gaskets, Should they be used? |
jack20 |
Apr 9 2020, 12:43 PM
Member Group: Members Posts: 412 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
Hello,
I had leaking pushrod tube seals and dropped the engine to make the job easier. I decided to pull the heads to check condition. I’ve done quite a bit of reading about whether or not gaskets should be used between the cylinder and case and between the cylinder and head. Some posters point to a service bulletin stating not to use gaskets. I have metal spacers/gaskets between the heads and cylinders. I think this engine has been rebuilt once before I got it. It runs well but it’s not as quick as another 914 2.0 I had years ago. Maybe the other car had higher compression and no gasket? I’m wondering if this metal gasket should be there. I haven’t checked for a gasket between the cylinder and case. My 356 has a thin copper gasket between the cylinder and case. Can anyone shed some light in this? Thanks in advance, Jack |
HAM Inc |
Apr 9 2020, 07:57 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
You will need to make sure you have adequate deck ht. No less than 1mm
The headgaskets are ~.8mm thick and do count as deck ht. If you don't use the headgaskets you may need to put a shim at the base of the jugs to achieve the proper deck ht. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:21 AM |
