FS Heater J Tube block off plates for cars with out heat, Set of two plates with hardware - $27.50 per set shipped |
bdstone914 |
Apr 1 2020, 11:34 AM
bdstone914 Group: Members Posts: 4,673 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Edit, Have ten more sets available.
I have seen many cars that deleted all of the heater parts and left the J tube holes in the tins open where the fan can suck hot air in. I made these to cover the holes and look better than a paint cap stuffed in the hole. I can supply them bare if you want to paint to a special tin color. Had them made from .047" mild steel. Bent the tuck tabs by hand. Each set consists of two plates , 6mm socket head screws. washers and nuts. Price is $27.50 per set shipped. PMs will be sent to those who replied to this thread. Attached thumbnail(s) |
chilling in vt |
May 28 2020, 04:21 PM
Newbie Group: Members Posts: 26 Joined: 2-August 05 From: Manchester, VT Member No.: 4,528 |
Not quite sure how the 914 heater hose sizing compares to a 911, but will these fit an early 911? Or do you make something like this for them?
bdstone914 |
May 29 2020, 09:05 AM
@chilling in vt
' date='May 28 2020, 03:21 PM' post='2819945'] Not quite sure how the 914 heater hose sizing compares to a 911, but will these fit an early 911? Or do you make something like this for them? [/quote] I think the 911 hole size is the same as the 914. Depending on what tin you have there may be a lip around the hole that may interfere. I have unpainted blanks. I can probably form a set to work but would need to know the sixe of the lip. Can you post a picture of that area of the 911 tin. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:18 PM |
