How do you start your /6 with carbs, Now with video |
PanelBilly |
Jul 2 2020, 03:48 PM
914 Guru Group: Members Posts: 5,840 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I turn on the key and pump the fuel a few times. Repeat MANY times. I’ve tried just holding the fuel open about 50% but that normally only gives me a backfire. Once it starts I need to give it a little extra fuel for 30 seconds or so and in runs fine. Normally the first time I pull out in traffic I need to pump a bit extra. After that it’s great. Running PMOs
roblav1 |
Jul 2 2020, 05:11 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Two or three full throttle down and up. Turn key, pump throttle. Rev at 2000 to 2500 rpm for a minute, then drive off. Same as 66/67 911. This is cold start. Hot start is simply hold pedal down halfway and crank.
Mark Henry |
Jul 3 2020, 07:51 AM
Two or three full throttle down and up. Turn key, pump throttle. Rev at 2000 to 2500 rpm for a minute, then drive off. Same as 66/67 911. This is cold start. Hot start is simply hold pedal down halfway and crank. Exact same, except mine would idle right off the bat (ambient 50F min) if I was to let it and I have WEB 120/104 mid/hot cams. I don't "warm up" my 3.0, I take off slowly at 2500-3000rpm till it warms up, but I have a down hill then a couple minutes of level country road. It's at least 5+ minutes till it's warmed up enough, 10-20+ minutes before my oil pressure starts drop from almost pinned to a normal hot range. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:27 AM |
