How to install the crush sleeve and the shiftknob ?, I must be a little stupid ...... |
Frankvw |
Oct 21 2020, 12:59 PM
working on my first 914 ! Group: Members Posts: 653 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Hi all.
Intro on issue: The shiftknob on my 73 1.7 was a bit loose. I pulled it off, came of easily. The crushsleeve also came out. I did not understand how to refit is so it was tight, so I searched on 914world. I read the trick to use a strip of paper or felt over the shifter and then push the knob over it.....and being Dutch that sounded like a cheap solution ! And then.... well...when I pushed down the knob I cracked the brittle original shiftknob in several pieces....unusable (IMG:style_emoticons/default/sad.gif) But I found a replacement one (it is same as original but I think it is from JP Group) It came with a brand new crushsleeve as well. The question (sorry if it is a bit stupid): HOW do I install the crushsleeve and replacement shift knob now on the shifter so it is secured and OK in place ? I thought to post the question before I mess up the new crushsleeve. Is it just drop the sleeve in the knob and then push down the knob on the shifter ? |
Lo-Fi Version | Time is now: 23rd November 2024 - 10:51 AM |
