I found a 911 front suspension, now what? newbee question |
Thierry |
Feb 8 2021, 09:32 AM
Newbie Group: Members Posts: 6 Joined: 18-November 15 From: The Netherlands Member No.: 19,379 Region Association: Europe |
Hi,
I recently bought a nice '76 2.0 that I would like to give some extra goodies. One of the projects I'm looking at is doing a 4-5 lug conversion. I read most of the articles describing the process of doing so and I think the route with a 911 front suspension is the way to go. So I found these parts of a (supposedly) 3.2 911 online but then the questions start popping up. The missing parts are break callipers and master cylinder. As I understand 3.2 breaks also use a break booster. Is that also needed or would a 19mm master cylinder also work fine? What breaks should I search for? What will work and is doable for a newbee 914 fan? Anyway, thanks in advance for helping my with my shopping list. Thierry |
ClayPerrine |
Feb 8 2021, 09:36 AM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You have everything you need there. But buy new rotors, and I would suggest finding a set of Boxster calipers and adapters for the brake calipers. They work great, and you can use a 19mm 914 master cylinder with them.
Clay |
Thierry |
Feb 8 2021, 10:48 AM
You have everything you need there. But buy new rotors, and I would suggest finding a set of Boxster calipers and adapters for the brake calipers. They work great, and you can use a 19mm 914 master cylinder with them. Clay Thank you for your help Clay, So you boxter brakes won't work with these rotors you mean? Any Boxter year breaks and adapter supplier you can recommend? Best regards, Thierry |
Lo-Fi Version | Time is now: 27th September 2024 - 10:08 AM |
