Fuel line fitting to gas tank, Fuel line fitting to gas tank no longer available |
growler |
Feb 23 2021, 02:36 PM
Newbie Group: Members Posts: 5 Joined: 19-August 17 From: Cheshire Ct Member No.: 21,361 Region Association: None |
Hello I am a newbie of sorts back at trying to put my 914 back together. I am working on the fuel system and have a new gas line from Tangerine installed in tunnel. I have twin carbs so I don’t need a return line. I am going to purchase a new tank but I see that the nuts and supply tubes are no longer available. I don’t have these parts? I am not a big fan of the tank connections anyway and I was wondering if I could get some suggestions on alternatives with a new tank?
bdstone914 |
Feb 23 2021, 07:50 PM
bdstone914 Group: Members Posts: 4,673 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hello I am a newbie of sorts back at trying to put my 914 back together. I am working on the fuel system and have a new gas line from Tangerine installed in tunnel. I have twin carbs so I don’t need a return line. I am going to purchase a new tank but I see that the nuts and supply tubes are no longer available. I don’t have these parts? I am not a big fan of the tank connections anyway and I was wondering if I could get some suggestions on alternativ (IMG:style_emoticons/default/smoke.gif) es with a new tank? @growler You can tap the inside of the threaded nipples to 1/4 pipe thread and install an AN 6 x 1/4 pipe and have a better gasketless setup. You will need an external filter. |
Lo-Fi Version | Time is now: 27th September 2024 - 11:37 AM |
