Programmable Type IV distributor, CB Performance Magnaspark II, NA or turbo motor up to 10psi |
Mueller |
May 15 2021, 01:46 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Brand new kit, comes with everything shown in pics.
$250 shipped in the USA Timing can be set with dip switches or with your laptop for a more custom table. Type IV sheet metal will need to be slightly modified to fit distributor. QUOTE CB Performance Magnaspark Digital Distributor Kit, CB2014 has more power built-in than most EFI computers! 21x21 fully programmable spark table, for the PERFECT ignition curve to benefit your engine and driving style! Programmable Rev-Limiter too! The Magnaspark Digital Distributor Kit is capable of holding 8 timing maps. It comes with 4 preloaded timing maps Single Carb Dual Carb Turbo, 10psi Boost For you to choose from. There is also room in the memory for 4 additional timing maps, for you to make and play with. Take an existing map, modify it, and re-name it! NOTE THIS DOES NOT FIT TYPE 3 NOR TYPE 4 ENGINES, WITHOUT MODIFYING THE COOLING TIN! |
Lo-Fi Version | Time is now: 27th September 2024 - 10:35 AM |
