What attaches to this engine ground lug? |
jrmdir |
Jun 21 2021, 10:25 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Hi:
Well I finally resolved my no spark issue but in the meantime noticed this empty - but used looking - spade lug on the top of the fan housing. Any info on what used to go there would be appreciated. '73 1.7L Thanks, Ron |
jrmdir |
Jun 21 2021, 02:38 PM
Thanks everyone - great info!
So the plot thickens. Looks like I'm going to need to investigate to find out what this car has in it. It was built October of 72 as far as I can tell from the chassis # (door jamb sticker is missing.) So if I understand correctly, the 73s had the heater fan grounded elsewhere? My fan is over in the driver's side corner with two wires going into the harness under the relay board. Thanks again, Ron |
JeffBowlsby |
Jun 21 2021, 02:59 PM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Thanks everyone - great info! So the plot thickens. Looks like I'm going to need to investigate to find out what this car has in it. It was built October of 72 as far as I can tell from the chassis # (door jamb sticker is missing.) So if I understand correctly, the 73s had the heater fan grounded elsewhere? My fan is over in the driver's side corner with two wires going into the harness under the relay board. Thanks again, Ron Sounds right for a 73-76 |
Lo-Fi Version | Time is now: 27th September 2024 - 08:29 AM |
