914 spitting / cutting out only when warm, lean or rich or ignition |
Medtner3 |
Jun 24 2021, 03:52 PM
Member Group: Members Posts: 183 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
My 2.0 D-jet has problem : Idles smoothly at start up and cold. As it warms up, it "spits" and cuts out and gets progressively worse the warmer it gets. Is this a CHTS problem maybe? I will test the ohms today and repost.
I thought this would be an ignition system fault such as a bad rotor / distributor or plug wire, but I noticed it gets twice as bad when I put the air box on. I can only increase the idle at the throttle body and not decrease and I believe the ECU knob is at the center (there's a mark on mine?) : 1) what would the default setting for ECU knob be and how to find it; 2) what is likely causing the "spitting" I don't see any vacuum leaks at all , and all my injectors are brand new, timing seems right as rain, and dwell and points are spot on, and my air temperature sensor is showing 195ohms, my CHTS is new. The AAR valve is working. Starts smoothly and idles low around 400 rpm not spitting at all , but after about 20-30 seconds idle jumps to 1100 rpm and starts "spitting" and so checked AARV it is closed Thanks in advance |
rjames |
Jun 24 2021, 04:04 PM
I'm made of metal Group: Members Posts: 4,111 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
My 2.0 D-jet has problem : at Idle, it "spits" and cuts out I thought this would be an ignition system fault such as a bad rotor / distributor or plug wire, but I noticed it gets twice as bad when I put the air box on. I can only increase the idle at the throttle body and not decrease and I believe the ECU knob is at the center (there's a mark on mine?) : 1) what would the default setting for ECU knob be and how to find it; 2) what is likely causing the "spitting" I don't see any vacuum leaks at all , and all my injectors are brand new, timing seems right as rain, and dwell and points are spot on, and my air temperature sensor is showing 195ohms, my CHTS is new. The AAR valve is working. Thanks in advance Default setting for the ECU knob somewhere near the center. (IMG:style_emoticons/default/biggrin.gif) Does the condition change when you turn the knob in either direction? (CW= richen mixture, CCW = leaner) Are you getting enough fuel to the injectors? (bad pump, clogged filter, etc.) Vacuum hoses hooked up correctly? Vacuum leak will cause a high idle, but shouldn't cause the engine to run rough, unless the MPS doesn't hold vacuum. |
Medtner3 |
Jun 24 2021, 04:24 PM
My 2.0 D-jet has problem : at Idle, it "spits" and cuts out I thought this would be an ignition system fault such as a bad rotor / distributor or plug wire, but I noticed it gets twice as bad when I put the air box on. I can only increase the idle at the throttle body and not decrease and I believe the ECU knob is at the center (there's a mark on mine?) : 1) what would the default setting for ECU knob be and how to find it; 2) what is likely causing the "spitting" I don't see any vacuum leaks at all , and all my injectors are brand new, timing seems right as rain, and dwell and points are spot on, and my air temperature sensor is showing 195ohms, my CHTS is new. The AAR valve is working. Thanks in advance Default setting for the ECU knob somewhere near the center. (IMG:style_emoticons/default/biggrin.gif) Does the condition change when you turn the knob in either direction? (CW= richen mixture, CCW = leaner) Are you getting enough fuel to the injectors? (bad pump, clogged filter, etc.) Vacuum hoses hooked up correctly? Vacuum leak will cause a high idle, but shouldn't cause the engine to run rough, unless the MPS doesn't hold vacuum. new MPS no vacuum leaks, all new hoses, all hooked up this isn't the problem the ECU seems to have no impact All that stuff in the fuel system is brand new and the pressure on the fuel regulator is correct I did note that the car starts idles very smoothly but seems a little low, then after about thirty seconds idle jumps to 1100 and it starts spitting. |
rjames |
Jun 24 2021, 04:31 PM
New MPS?
If the issue started immediately after installing the MPS, have you vacuum tested it and calibrated it for your engine? If the ECU knob doesn't have any affect then you are way too lean or too way rich. If it was rich enough to make the ECU knob useless, then you'd probably be flooding your engine and you'd smell gas, so I'm guessing you're way lean, in which case I'd suspect the MPS. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:45 PM |
