OT: BMW radiator help..., coolant leak on my e30... |
cha914 |
Jan 1 2005, 01:00 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
So my e30 has always had a slow coolant leak, never really thought much of it, would just add a little bit when it got low, but now it seems to be getting worse...
So I get the car up in the air and start poking around and find two open ports on the drivers side of the radiator???WTF??? There are no disconnected hoses, what the hell are these for, and why arn't they capped off? My best guess is that this is a replacement radiator that is setup for a different car, auto tranny cooler maybe? Should I just cap them off, and if so, do I need any special caps? First watercooled car, still donno shit about the new fangled things (IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif) Thanks for the help, here are the pics: From the bottom of the car you can see where the coolant was leaking onto the plastic undertray: Attached image(s) |
cha914 |
Jan 2 2005, 11:42 AM
Kargeek,
Its a 325, so I have the six, but I should probably test the system anyway, thanks for the tip... iiibdsiil, I will run down the heater core also...just hit 145K on this car, so i am sure there are some other items I am neglecting, luckly I was smart enough to do the timing belt/water pump right after I got it...now its just the little stuff... Thanks again, Tony |
Lo-Fi Version | Time is now: 27th September 2024 - 02:17 PM |
