Retractable Headlights & High Beam Issues, Light Problems |
MFejsa |
Sep 23 2021, 09:34 AM
Newbie Group: Members Posts: 40 Joined: 25-April 20 From: Saudi Arabia Member No.: 24,178 Region Association: None |
Hi, need some serious help. See below issues.
1. Cannot get high beams to work and power to the fuse. Low beams are working 2. When the engine is running cant get the retractable lights to come up. When the engine not running, the retractable lights come up and lights work. Can anyone give me some advice? Regards Michael |
Mikey914 |
Sep 23 2021, 11:54 AM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Will the lights come on when the key is in the running position, engine not running. They should work then, but in accessory position no it will not raise.
If so that is normal. For high beams I suspect fuse, switch or relay issue. Hopefully not switch. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:36 AM |
