Retractable Headlights & High Beam Issues, Light Problems |
MFejsa |
Sep 23 2021, 09:34 AM
Newbie Group: Members Posts: 40 Joined: 25-April 20 From: Saudi Arabia Member No.: 24,178 Region Association: None |
Hi, need some serious help. See below issues.
1. Cannot get high beams to work and power to the fuse. Low beams are working 2. When the engine is running cant get the retractable lights to come up. When the engine not running, the retractable lights come up and lights work. Can anyone give me some advice? Regards Michael |
Mikey914 |
Sep 23 2021, 11:54 AM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Will the lights come on when the key is in the running position, engine not running. They should work then, but in accessory position no it will not raise.
If so that is normal. For high beams I suspect fuse, switch or relay issue. Hopefully not switch. |
MFejsa |
Sep 24 2021, 09:45 AM
Will the lights come on when the key is in the running position, engine not running. They should work then, but in accessory position no it will not raise. If so that is normal. For high beams I suspect fuse, switch or relay issue. Hopefully not switch. 1. When the key is on accessories position, the lights (low beam) work and come up. When the engine is running I am unable to get the lights to retract to upright position. 2. When the low beam are on, I cannot get the high beams to work when I flick the light switch to operate high beam. Also no power come to or out of fuses #1 & 2. Ive replaced the headlight relay with new one, and also the light switch level is new. Dont understand why cant get power to fuses as I have power in yellow & white wires from headlight relay. Can you confirm if yellow wire goes to 56a or 56b on the relay? |
Lo-Fi Version | Time is now: 27th September 2024 - 06:37 AM |
