Engine cuts out, FI problem??? |
EJP914 |
Sep 26 2021, 06:41 AM
Member Group: Members Posts: 262 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Hello,
I have a '73 1.7 car with fuel injection. Just starting to get it back on the road after sitting for many years. The car starts easily, idles well, and seems to run ok when warming up. Once warmed up and on the road, intermittently the car will stumble like shut off and then just as quickly it will go again. Going around corners, not all corners, it will do the same but for longer periods of time. Pushing on the gas when this occurs, nothing happens. The engine doesn't rev. its like its disconnected. I recently changed the fuel lines at the fuel pump due to age and cleaned out the fuel injectors. Car has about 5 gal of gas in it. Any ideas on where or what to look at first? Does this sound like a FI related problem? Thanks for the advice. EJP914 |
EJP914 |
Sep 26 2021, 06:13 PM
Thanks for the tip on watching the tach. Will check that out next time out.
I did put in a new fuel filter figuring there would be some crud in the tank since the car has sat for so long. I thought it might be a fuel delivery issue too, but wouldn't that show up at idle or when the car is just warming up? Cut out seems to happen only after driving a while and car is warmed up. Thoughts? |
Lo-Fi Version | Time is now: 27th September 2024 - 08:01 AM |
