123... and your oils on the driveway, not the crankcase., If something can go wrong... |
emerygt350 |
Nov 6 2021, 02:09 PM
Advanced Member Group: Members Posts: 2,530 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
So.... Bought a 123injection distributor from tangerineracing and installed it nice and easy. Started it up to set the timing and I hear this weird slurping noise.
That nearly irreplaceable hose that goes from the block to the remote oil pressure sender had finally given out. Chris is trying to find the appropriate fittings to replace it. Also, chasing a vacuum leak around the intake on cylinder 4. Just replaced the spacer a month ago and really was careful with the blue gas safe sealer etc. The injector seals are all new. Spraying very carefully it really does appear to be the area near the spacer. Any tips and tricks? Nobody would ever suspect a 914 is behind that door... |
iankarr |
Nov 7 2021, 03:35 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,528 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The OEM sender is screwed directly into the block. The metric to NPT adapters on eBay work fine. Running them on my car now.
emerygt350 |
Nov 7 2021, 04:18 PM
ChrisFoley |
Nov 8 2021, 05:22 AM
I am Tangerine Racing Group: Members Posts: 7,970 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The OEM sender is screwed directly into the block. The metric to NPT adapters on eBay work fine. Running them on my car now. But the dual sender can't handle the heat or something? Man it would be nice to just screw that straight in. Isn't distributor interference the biggest issue with direct mounting the VDO sender? They make one with the M10 tapered thread if I'm not mistaken. |
Lo-Fi Version | Time is now: 6th January 2025 - 06:56 PM |
