WTB Console Parts, Hardware Needed |
NARP74 |
Feb 1 2022, 01:43 PM
Senior Member Group: Members Posts: 1,175 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I picked up a decent center console but it had no hardware. I have looked around and asked my local sources, came up empty. Anyone have this lying around and want to let it go? Let me know.
U bracket for console to car body, X1 Screws and washers for the U bracket to body, X2 Screws and washers for the U bracket to the console, X2 Spring clips for the upper gauge pad to the console, have the bracket, X2 Bracket for the lower pad to the console in front, have the clip, X1 Screws for the bracket to the front of the console, X2 Plastic trim filler for the heat lever slot, X1 Screw and washer for the bracket to the car floor mount, X1 Thanks |
NARP74 |
Feb 1 2022, 05:06 PM
Thanks, I only need 2 of those brackets and all of the hardware which isn't mentioned in the ad. I will try to get in touch with them and see if they can do something.
rgalla9146 |
Feb 1 2022, 08:30 PM
Advanced Member Group: Members Posts: 4,624 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Thanks, I only need 2 of those brackets and all of the hardware which isn't mentioned in the ad. I will try to get in touch with them and see if they can do something. You still need the U bracket ? I have one ( flat U bracket ) on the shelf but must check that it is not from one of my cars. I'll check tomorrow. |
NARP74 |
Feb 3 2022, 12:31 PM
Thanks, I only need 2 of those brackets and all of the hardware which isn't mentioned in the ad. I will try to get in touch with them and see if they can do something. You still need the U bracket ? I have one ( flat U bracket ) on the shelf but must check that it is not from one of my cars. I'll check tomorrow. Any update? @rgalla9146 |
rgalla9146 |
Feb 3 2022, 02:10 PM
Thanks, I only need 2 of those brackets and all of the hardware which isn't mentioned in the ad. I will try to get in touch with them and see if they can do something. You still need the U bracket ? I have one ( flat U bracket ) on the shelf but must check that it is not from one of my cars. I'll check tomorrow. Any update? @rgalla9146 I'm sorry for the delay I cannot get to one of the cars ( I have two early ) so have to say I can't help you out. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:50 PM |
