I was bored so decided to drop the engine, Oh my!! |
BK911 |
Feb 17 2022, 11:42 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
So many oil leaks.
Even had oil mist out the windshield defrost vent! What causes so much oil around the cylinder/case interface? Pretty wet on both sides. Side where I attached the oil breather to air cleaner has built up oil on back side of intake valves!! Have to figure out a better way for head and case vent. On a positive note, 6 8 6 6 % leakdown!! |
DRPHIL914 |
Feb 17 2022, 01:32 PM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
So many oil leaks. Even had oil mist out the windshield defrost vent! What causes so much oil around the cylinder/case interface? Pretty wet on both sides. Side where I attached the oil breather to air cleaner has built up oil on back side of intake valves!! Have to figure out a better way for head and case vent. On a positive note, 6 8 6 6 % leakdown!! check you head bolt torque, if you have good leak down and compression was good, then rings should be ok, but you’d get some oil leaking by case/cylinder interface over time the loosen- 4 years ago when i pulled mine to paint, mine were only 12-15ft# should be 25 or 27# i believe, no leaking after that- |
ClayPerrine |
Feb 17 2022, 03:07 PM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
So many oil leaks. Even had oil mist out the windshield defrost vent! What causes so much oil around the cylinder/case interface? Pretty wet on both sides. Side where I attached the oil breather to air cleaner has built up oil on back side of intake valves!! Have to figure out a better way for head and case vent. On a positive note, 6 8 6 6 % leakdown!! check you head bolt torque, if you have good leak down and compression was good, then rings should be ok, but you’d get some oil leaking by case/cylinder interface over time the loosen- 4 years ago when i pulled mine to paint, mine were only 12-15ft# should be 25 or 27# i believe, no leaking after that- Cylinder head torque is 23 FTLbs. Clay |
Lo-Fi Version | Time is now: 27th September 2024 - 02:00 PM |
